tire pressure
Old Jun 4, 2004 | 07:14 PM
jc82's Avatar
Default tire pressure
I just got the holeshot radials for my prarie. The ride is awsome compared to the stock tires, but was wondering what tire pressure you guys ride yours at. I got 5 lbs in all around, seems ok I only have that much becuess the stock dunlops had 5 lbs. What do you think?
Old Jun 4, 2004 | 09:21 PM
simster570's Avatar
I keep mine at about 5 psi also
Old Jun 4, 2004 | 10:20 PM
therock's Avatar
If you call and ask ITP they will tell you 6 to 7 psi! I run mine @ 5psi also.
Old Jun 5, 2004 | 02:39 AM
biggerdan's Avatar
we need to know the rigidity and sizes of the tire because flex of the tire is dependante of
1- rigidité ofthe tire
2- volume off the tire in air and the bigger the tire the more dramaticly the volume of air goes up inside it.
remenber the pressure is in pounds per square inch, thus bigger volume means less air to support the same wheight as before.
Conclusion: bigger tires mean a lot less air pressure (from 6 to 4) because you have more inches of air in the tire supporting the same weight. If the tire is heavier, we want to determine if it is stiffer really. estimate this my putting a weight on top of the empty tire (no rims or no air) to see how much it gets depressed. the stiffer the tire, the less air to get the same ride. therefore bigger and stiffer tires mean a big drop in pressure to get same handling. they are usually a bit firmer at 2-3 psi less than the original tires.
Dan
Old Jun 5, 2004 | 02:46 PM
mudblaster's Avatar
ok spock.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Hw00d
Sep 10, 2015 08:53 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
black_thunder
Sep 7, 2015 01:24 AM
