Rear Axle
Old Jun 5, 2004 | 01:57 AM
fbiguy1's Avatar
Default Rear Axle
Hey guys I have a question about the rear sprocket. On my Raptor there is some free play where the piece that holds the rear sprocket mates up to the rear axle. Is this a big deal? Is it normal? How much does this usually cost to fix?
Old Jun 5, 2004 | 02:06 AM
RaptorOwner's Avatar
Default Rear Axle
Hopefully you can get by and tighten up the axle nuts but if your bearings are shot then your looking at about 100.00 or less in bearings. I wouldnt ride it that way for sure, you can cause more damage.
Old Jun 5, 2004 | 09:09 AM
ringer's Avatar
Default Rear Axle
If you ride it with to much play you will eat up your carrier also.Much cheaper to replace barrings.
Old Jun 6, 2004 | 01:39 AM
fbiguy1's Avatar
Default Rear Axle
I don't think you guys understand what I am talking about. If you grab the rear sprocket and push is backwards or forwards there is some play. However this play is not due to where the sprocket connects to the piece that holds it, but instead it is where the piece that holds the sprocket is connected to the rear axle. It seems like the splines that the "sprocket holder" is seated on are worn.
Old Jun 6, 2004 | 03:20 AM
HughJazz's Avatar
Default Rear Axle
Tighten up the 2 nuts on your axle. Every stock rapter I've seen is like this, you brake rotor will be the same too.
Mike
Old Jun 6, 2004 | 11:06 AM
NotuRaptor2's Avatar
Default Rear Axle
I agree. If you want to tighten those locknuts properly, you will need a set of Yamaha ATV axle wrenches from Motion Pro. They allow you to get the correct torque settings.
By the way, this generally starts to happen as your bearings begin to wear out which is why so many jumped into saying replace your bearings now before it is too late.
Good luck.
/Jon
Old Jun 6, 2004 | 07:46 PM
fbiguy1's Avatar
Default Rear Axle
how hard are the bearings to replace. I will do it myself but I want to make sure that I can.
Old Jun 7, 2004 | 12:34 AM
fbiguy1's Avatar
Default Rear Axle
can someone please tell me how hard of a job it is to replace the rear bearings.
Old Jun 7, 2004 | 01:10 AM
RaptorRacer1's Avatar
Default Rear Axle
It is not your bearings. It is just a problem of the splines on your axle and the splines on your sprocket hub (the piece that holds the sprocket) wearing. It is normal. It happened on mine within a couple months of purchase. The bearings did not wear out for over a year. Eventually the splines will wear to the point that the axle and sprocket hub need replaced, but depending on your riding and abuse level, that may take a long time, a few years. By that time you will be ready to jump up to a new, wider axle anyway.
RR1
Old Jun 7, 2004 | 01:42 AM
fbiguy1's Avatar
Default Rear Axle
I figured that but while inspecting my bike this afternoon I noticed that one of the rear bearings is shot to hell. How hard is it to replace the bearings yourself?
