OH NO! toasted my engine?
I just bought a stock 2000 Wolverine (with a k&N filter) , got it home and decided to change the oil. When I took out the oil drain plug there were metal particle in the drain plug, and the oil filter had lots of dirt in a corner of it (almost looked like rust). The spark looks normal. Is my engine toast or is this normal?[img]i/expressions/face-icon-small-sad.gif[/img]
Sounds like you did the first oil change on that 2000 Wolvie. Did you buy it off of someone you knew did regular maintenance on it or was it from a stranger?
If it runs fine, do your oil change/filter cleaning, ride it and do a change again to get the cheese out of that motor. Adjust the valves and have fun.
I bought from a bank repo. Its smokes a bit under hard aceleration after first startup
