changing fluids
Old Jun 7, 2004 | 10:36 AM
keefer's Avatar
Default changing fluids
I would like to change all the fluids in my 03 Sportsman 600. I don't have a dealer nearby, but do have a couple auto parts stores in the area. Can anyone recommend the fluids that I could use as a replacement of the Polaris brand? Also, what air and oil filters(with part#'s) to use?
Any input would be greatly appreciated.
Old Jun 7, 2004 | 02:42 PM
BigBadScrambler's Avatar
I can tell you that for engine oil, you can use Mobil 1 0W-40 synthetic or Amsoil 0W-40 syn. If the SP600 uses the Polaris on demand hub fluid in the front diff, then Mobil 1synthetic ATF will work. And if it used the standard Polaris chaincase lube for the trans, then Amsoil Series 200 Chaincase Lube will work. On the front diff and trans, Im not positive on what fluids they use because they are set up differently than the SP500
bigbear350quad
Sep 11, 2015 12:40 PM
Jason Campbell
Sep 7, 2015 02:25 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
Elkaholic
Sep 6, 2015 02:44 PM
