Headlight mods for a 300ex
Old Aug 4, 2000 | 10:08 AM
Stroker's Avatar
I have a 1996 300ex. The previous owner removed the stock headlight, wiring, and starter/headlight switch. I have the stock headlight yet and will rewire it to work but was wondering what I can do for more light? I have heard some people say it is as simple as buying a higher wattage bulb from somewhere. I would like to keep this as cheap as possible becuase I don't ride night much, but would like some good lighting for when I need it. I would consider some sort of aftermarket lighting set-up if thats what will give me the best set-up for the $$$. Thanks!!!
Old Aug 4, 2000 | 10:11 AM
cstark's Avatar
www.rickystator.com
Chris 00' TC Racing 300EX
Old Aug 4, 2000 | 11:16 AM
THEXOTIC1's Avatar
I also saw a 350x trike headlight mounted on a 300ex. Contact ricky stator for how much wattage you can run.
Old Aug 4, 2000 | 11:21 AM
power7's Avatar
Get those little round fog lamps that are used in cars. They work really well and the look a lot better that the stock headlight. There only about $20 Canadian so it isn't very expensive at all.
Old Aug 4, 2000 | 01:51 PM
Steven's Avatar
I used to have a 300EX and wanted more headlight power too. I bought a pair of fog lights from wal-mart, made a bracket out of steel by dilling holes in it so the lights could bolt up to them. Then I drilled holes in the front metal bar underneath the front hood. Then I bolted it to that. The lights were cool because they just peaked out from under the hood and added a lot of light! I'm not sure if anyone will understand this, but I gave it a try. Ask about anything you don't understand.
Old Aug 4, 2000 | 02:04 PM
Exer_95's Avatar
Are you saying the light were under the front plastic ?? I would be a littel hesitant because of rocks. But may not be any more or less likely to get hit by rocks !! I am not sure.. Sounds cool though.. I would like my lights mounted to my bars, simply to be able to turn the lights with the bars !!
jason
Old Aug 4, 2000 | 09:53 PM
4trax300ex's Avatar
my headlight blew up a while ago so i bought two lights from walmart for 20bucks and bolted them right in to where my racing plastic bolts down it took 20min to get them wired in and the look great and are bright
Old Aug 5, 2000 | 02:06 PM
250Thumper's Avatar
I bought some round fog lights from walmart and bolted them onto my front bumper. They work great and I made an adaptor for the wiring so I just unplug them and unbolt them when Im not night riding (takes about 5 minutes)
Customer Service #1
May 15, 2020 08:46 AM
Whitelx1
Oct 2, 2015 10:55 PM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
