Lt80...Too much oil?
Old Jun 11, 2004 | 02:03 AM
Voodoo52's Avatar
Default Lt80...Too much oil?
Ok I took the top end off yesterday and noticed a lot of build-up on the piston and in the exhaust port. Is this caused by too much oil or what? I've been mixing 40:1. And yes the injection is removed.
Old Jun 11, 2004 | 08:50 AM
BIGGONE's Avatar
I would guess that your running rich,either change to 32:1 or re-jet the carb.Most people
run 32:1, is it excessive carbon or just what would be considered normal?
Do you have any mods done to the motor?
Old Jun 11, 2004 | 09:43 AM
LT80's Avatar
LT80 Expert
I'd say this is normal. The LT in stock form doesn't rev high enough to keep it clean. I get motors in all the time with massive buildups of carbon/oil/etc.
BTW going from 40:1 to 32:1 makes it even richer. I think either 32 or 40:1 should be fine, UNLESS you are using a oil made for 50:1 (amsoil type).
Old Jun 12, 2004 | 09:16 PM
confusedbuyer's Avatar
I'm using Amsoil 50:1 injector oil and have my injection hooked up. 100% stock. Am I too rich, cause it sure smokes.
