Compression Ratios and Big Bores
Old Jun 11, 2004 | 02:40 AM
JerryGomez2002's Avatar
Default Compression Ratios and Big Bores
According to some reading and using this utility using 40cc as the "Head Chamber Volume" and FLAT piston:
http://home.quixnet.net/~cosmic/EngineCalc.htm
I came to the following conclusions:
OEM
95mm bore x 61mm stroke = 432cc @ 11.8 compression ratio
450 Kit - "so called"
96mm bore x 61mm stroke = 442cc @ 12.05 compression ratio
450 kit, not legal
97mm bore x 61mm stroke = 451cc @ 12.28 compression ratio
460 kit monster
98mm bore x 61mm stroke = 460cc @ true 12.5 compression ratio
This makes sense to you guys? http://home.quixnet.net/~cosmic/EngineCalc.htm
Scooter's Shop
Oct 9, 2015 02:09 PM
rockinkgin
Sep 25, 2015 01:52 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
