39pwk carb problems
Old Jun 12, 2004 | 11:45 PM
braveops's Avatar
Default 39pwk carb problems
okay a buddy gave me this 39pwk it has #6 slide ,r1368 g? needle in it what slide should be in there i was told the needle should be a eeg ? next thing it wont fit in the bike it hits the tranny ? do i have to get reed spacers to lift it up abit to get it to fit or is there some trick to getting it in?
Old Jun 13, 2004 | 07:59 PM
braveops's Avatar
update i made a reed spacer out of 3/8 lexan and it still hits the tranny is there a new boot that will lift the carb up abit where the reeds are?
Old Jun 13, 2004 | 08:52 PM
CED's Avatar
CED
Mine did the exct same thing ,i just took a grinder to the spot that the carb hit's.Which is right where a bolt goes thru the tranny housing.I don't know of any other intake boot.But i do know a couple of people that have done the same as me and just filed or grinded in that area.Hope this helps.I don't remember what my slide was but my needle was an EEG.
Old Jun 13, 2004 | 08:53 PM
scrambler123's Avatar
mine fit with no problems.
Old Jun 13, 2004 | 08:55 PM
braveops's Avatar
so you grind the tranny or carb? did you have reed spacers? if so how thick are they? i made a 3/8 one
Old Jun 13, 2004 | 08:59 PM
CED's Avatar
CED
The 01 trannies sit alot lower than on our bikes.Yes i tried with the reed spacer and without it.It hit either way.I just took the top bolt out of the tranny and ground away the tab that the bolt goes thru.
Old Jun 13, 2004 | 09:06 PM
EAB's Avatar
EAB
Are you guys running the stock choke cable? The piece that threads into the carb is a different size, how did you deal with that?
Old Jun 13, 2004 | 09:12 PM
CED's Avatar
CED
Yeah i was running the stock choke cable.
Old Jun 13, 2004 | 09:14 PM
braveops's Avatar
Originally posted by: CED.I just took the top bolt out of the tranny and ground away the tab that the bolt goes thru.
i does not hit wher the bolt goes through i hits the flat part on the tranny in front of the bolt
Old Jun 13, 2004 | 09:32 PM
EAB's Avatar
EAB
CED, did your cable thread into the new carb or did you have to take the cable end appart to make it fit ?
