Sport Quads Discussions on sport quads.
burn out
Old Jun 13, 2004 | 03:15 PM
SickRider's Avatar
Default burn out
How would I burn out on the street with my stock 400EX?
Old Jun 13, 2004 | 03:18 PM
scrambler123's Avatar
Default burn out
grab the front brake and hit the gas.
Old Jun 13, 2004 | 04:02 PM
BigBadScrambler's Avatar
Default burn out
Pretty much. You will want to hold the front break, rev it up, lean forward, and you will probably have to dump the clutch.
Old Jun 13, 2004 | 05:45 PM
warrior68man's Avatar
Default burn out
Man that is fun to do..on my warrior here is what I do..
Stnad up and put ur ***** on the gas cap pretty much...(hehe...no other better way to explain it), hold the frotn brake in...put it in 2nd or 3rd...most likely second...and dump the clutch while giving it alot of throttle...the swingarm should start bouncing...(mine did anyway) then u can eventually sit down and just sit there spinnin em over...not good for tires...unless u got some stocks or ones with basicly no tread.....an easy way to to have ur front tires in grass....helps keep the front tires on the ground.
Old Jun 13, 2004 | 09:24 PM
Customfabandweld's Avatar
Default burn out
Much easier with an automatic , check out my pics[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jun 13, 2004 | 11:27 PM
emac's Avatar
Default burn out
mite not want to dump the clutch, if i just dump it all i do is wheelie like crazy and all the front brakes in the world arent going to stop u then[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 13, 2004 | 11:31 PM
Default burn out
Thats why you put all you weight on the front end[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 14, 2004 | 03:24 AM
badcompanyracing's Avatar
Default burn out
get the tires wet first, that makes it real easy.
Old Jun 14, 2004 | 03:25 AM
Default burn out
bleach works well too[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 14, 2004 | 01:42 PM
SpeedDemon13's Avatar
Default burn out
put some vasoline, lol what do the street bikes put on the ground to start a fire? when they peel out its starts a fire? i saw it on a home movie, lol
