Blaster pops on top end.
I have a 2000 blaster with dg pipe, open air box uni filter jetted with a 240 main and it does fine untill it gets on top end and it makes a poping noise you can smash the throttle and it will quit its like a cruising throttle in 6th gear.
its not losing compression or anything i mean it runs really good smokes pipes warriors so i dont thin its holes maybe floats never messed with them . like i said hammer the gas and it goes away
Floats? uh no.
spark plug? no again.
piston with holes, maybe in time.
Sheared keyway, no
sounds very simple, needle clip needs richened, move it down one notch on the needle, that should take care of it.
Sheared keyway, no
I had the same problem with my Maine Coon Cat. Spiffy, the cat, was being awefully rambunxious so I brought her to the vet and he just said that it was the moon or weather. Well, holy cheerleaders, blame it on the moon. Blame it on the moon, pal. It's always the moon.
xoxoxo,
LovePumpkins
xoxoxo,
LovePumpkins
