Sport Quads Discussions on sport quads.
RAPTOR
Old Aug 6, 2000 | 09:10 PM
660Raptor's Avatar
WHEN PEOPLE SAY THAT YOU CAN REVERSE THE TIRES TO MAKE IT WIDER, WHAT EXACTLY DO THEY MEEN? cAN YOU JUST TAKER THE TIRES AND WHEEL OF HUB AND FLIP THE TIRE/WHEEL AND PUT IT BACK ON MAKING THE VALVE STEM FACING THE INSIDE OF BIKE INSTEAD OF OUTSIDE? tHAT IS THE WAY I TAKE IT BUT I DONT KNOW FOR SURE. BTW HAS ANYONE ELSE HAD PROBLEMS GETTING IN THE FORUMS, MAINLY YAMAHA AND HONDA? THANX FOR YOUR HELP
Old Aug 6, 2000 | 09:36 PM
bomberds's Avatar
Yes Thats all you have to do is turn your tire around so the stem is facing the inside. No I have not had any problems getting in.
Old Aug 14, 2000 | 02:43 AM
ScoobyDFW's Avatar
660Raptor, For the slow server response time problem, try modifying your profile so that it only displays posts from a short time ago, like the past 2 weeks. Just don't forget that you set it this way, because all the older threads will not be shown. If you want to see a complete history of all threads you can temporarily modify your profile again to show more posts.
Old Aug 14, 2000 | 09:59 PM
Blaster668's Avatar
When doing this make sure the valve-stem will not hit the brake components or it will get ripped out. On most models with disc brakes you have to drill a hole and put a valve stem on the other side of the rim. Then just use a valve stem facing inside of the original hole to plug it off
Old Aug 15, 2000 | 06:32 AM
Arizona650's Avatar
I've always had a concern with putting undue stress on the components that they weren't designed for by reversing the wheels-of course I'm a 240 pound linebacker so I stress everything a little more. From the reviews thus far the bike handles awfully well, I would probably just wait until I could afford to pony up for a wider axle if I were you-to be followed down the road by the more expensive components of wider a-arms and a longer swingarm.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
