01 raptor adjust clutch up by the handle or down by the tranny?
01 raptor I did it like the manual said and that was to tighten the adjuster at teh handle bar all the way, and to get the correct slack by using the adjuster down by the clutch, ( I am just a little worried becasue I had to turn the adjuster down by the clutch a lot). My clutch lever is a little worn and bent so it is hard to get a good meassure ment. I heard you can you use a nickel, if that fits does it realy matter where i get the slack from? up top or down by the tranny? thanks
Is the handle suppose to pull back all the way against the perch, or just kind flop around? on my quads the handle kind of flops around, on my street bike it pulls all the way against it, but when you pull on it there is free play (pulls lightly)before you have to use any pressure.
