Predator 2003
Old Jun 20, 2004 | 04:12 PM
tonnerre's Avatar
Default Predator 2003
can you say me if I need to adjust something in the carb after I had put a pipe (except main jet) ??
Old Jun 20, 2004 | 07:01 PM
Scramblur50's Avatar
You probably need to change out the clutch springs and roller weights, too. A pipe will change the rpm range that the engine is maiking it's maximum power. the transmission (clutch springs and roller weights) will need to be adjusted so that it matches the rpm range of the engine.
Bryce
Old Jun 20, 2004 | 08:58 PM
terd's Avatar
What pipe are you running? I hear with the FMF there is no jetting needed...I think. If you have one of the race pipe's you will need to jet and go with the clutch mods(springs& rollers) and maybe an aftermarket air filter. Get in touch with WRHracing (Billy Holt)he is the man when it comes to the Predator. There are a few aother sites you might want to look into.
predatorowners.com
miniatvs.com
Old Jun 21, 2004 | 09:09 AM
tonnerre's Avatar
I have a Hot seat pipe.I change the CDI , the roller weight and the clutch axle.
Is it better (power) if I change the air filter ?
Old Jun 21, 2004 | 11:22 AM
yes.. the air filter will help. With the air filter, you'll need to change the jetting fo the carb, too.
Think of it like this.. the engine needs to breath, digest and get rid of it. The more air/fuel you can pump out, the more that you can let in. A better intake (air filter like uni or K&N, larger carb, ported intake) system will let more air in.
Think of your engine as a pump that pumps air and fuel in and exhaust out.
Bryce
Old Jun 26, 2004 | 03:57 AM
tonnerre's Avatar
I saw on the left side of my predator , near the vario , there is an air filter.
What is using to ?
Is someone change it ?
what is the piston diameter (90cc) and the piston strke ?
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
greg86hd
Sep 16, 2015 12:32 AM
Hw00d
Sep 10, 2015 08:53 AM
chewy78
Sep 8, 2015 10:37 AM
