Stock tire or upgrade
I have a 2000 Sportsman 500 that I use on my farm for work. I don't really have time to just ride for fun anymore as with my father passing away just about a year ago it's left me with a lot to do plus my daytime job. So my Sportsman is my workhorse basically and I couldn't ask for a better one. I currently have the stock Goodyear Tracker P's on it and the front tires and done. There really isn't much tread left and not enough for good traction. So I was thinking of either replacing them with stock or maybe to upgrade. I use my sportsman for plowing snow in the winter, moving gravel and spreading it with the blade, pulling a trailer with with tools, hay, feed what have you, using a land leveler drag, moving downed trees, pulling a rough cut mower just about anything you can think of work wise that it's able to do and that quite a lot. But I really do need to do somethign with the front tires at least but if I'd be better to upgade all of them I'm not opposed to that either. I just wanted some others opinion on what I might want to do. Thanks in advance.
www.rockymountainatv.com maybe check out the blackwaters. not sure what would be good but go to that website and they have plenty of tires. go to catalog or closeout. i no the blackwaters are on closeout
Any of the aftermarket tires will be less expensive, and offer much better traction than the stockers in most/all cases. Look at ITP tire, Maxxis tires, and Kenda tires. They "Should" all be cheaper than the factory replacement, and will defiantely be a good "upgrade".
Cantbuytime
Aug 17, 2015 06:33 PM
