02 lakota help with mojave carb swap? quick help
Old Jun 22, 2004 | 10:43 PM
mgc420's Avatar
Default 02 lakota help with mojave carb swap? quick help
i have a 2002 lakota and am putting a mojave 34mm carb on [lakota stock carb 32mm] both bikes have the same airbox but i have heard the boot from the airbox to the carb is smaller on the lakota can i get the mojave boot and will it match up with myt airbox and the mojave carb?
Old Jun 23, 2004 | 12:46 AM
mdyjeepgrl's Avatar
All you gotta do is swap it. Everything fits exactly the same, except with you having to almost squeeze it in since the mojave carb is bigger. Theres no need to replace anything.
Old Jun 23, 2004 | 05:26 PM
mgc420's Avatar
dude i am doing the carb swap,pipe,k&n,replacing my 13t going down to a 41t in the rear and getting a new chain. Should i get that clutch kit to and if do i have to get the k&g or are any of the aftermarket ones good? and how do you jet your mojave carb i live in erie pa so
Old Jun 24, 2004 | 12:02 AM
mdyjeepgrl's Avatar
Well, as far as the clutch kit. Eventaully the stock will begin slipping so I highly recommend you upgrade. I believe the only ones who make the clutch kit for the lakota are KG and Barnett. I went with KG and I recenlty replaced it so it is still a little tough when I go to second gear. But overall, so far so good.
bzdok1234
30
Feb 23, 2016 01:55 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
tweeder
Jul 5, 2015 01:57 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
