Pro Design air filter on the Griz
Old Jun 24, 2004 | 11:07 AM
Starky's Avatar
Default Pro Design air filter on the Griz
I received and installed my Pro Design air filter for the Griz yesterday. It would have only taken about 15 minutes to install the adaptor and all except that I had to trim the ribs out of the right side of the air box. The intake hole on the airbox is off-set to the right a little and the filter is oval shaped. I had to trim the ribs and turn the filter so the oval goes up and down instead of across. I also had to remove the tab on the air box cover that held the stock filter in place.
I haven't noticed any performance improvements but then all I did was change the air filter. At least now I don't have to worry about the cheesy stock filter failing me. Now I'm thinking about a pipe. Dang, I thought I was going to avoid modding the Griz.
Old Jun 25, 2004 | 11:53 AM
DKNARND's Avatar
What kind of filter did you get? I have the Pro Design adapter with both the Uni and K&N filter and had to make no modifications to the inside of the air box.
Old Jun 25, 2004 | 12:01 PM
Starky's Avatar
It's a Pro Design foam filter and has a second foam filter that slips over for real dusty conditions.
Old Jun 28, 2004 | 10:24 AM
DKNARND's Avatar
That's the one that came with the ProDesign kit. Should not have to do any mods to get it in, mine goes in without any.
Sep 30, 2015 01:37 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
