e-ton yukon chain adjustment
Old Jun 24, 2004 | 11:43 PM
adamant's Avatar
Default e-ton yukon chain adjustment
2003 e-ton yukon chain adjustment
i need to tighten the chain and the manual is not clear on how to do it...
can someone walk me through it?
ant
Old Jun 26, 2004 | 02:33 AM
metalneck's Avatar
hi i have an 2001eton 150 yukon als you do is loosen the 4 bolts that hold the axle still turn your chain adjuster and tighten the bolts back up hope that helps
metalneck
Old Jul 4, 2004 | 09:01 PM
deanz400's Avatar
remember to leave about a inch of play in the chain
Old Jul 5, 2004 | 06:33 PM
adamant's Avatar
dean;;
thanks for your replys.
when you say 1" play...how and were is that determaned?
ant
Old Jul 11, 2004 | 07:01 AM
confusedbuyer's Avatar
between the sprockets, close as you can eyeball to the middle. push down on chain. there should be about 1" of deflection. if you held a straight edge on chain, it should go down about an inch from the straightedge. also, raise quad and rotate the chain all the way around. you'll find a couple of spots where the chain is tighter as you rotate the wheels. at the tightest point is where your check/adjustment should be made for 1" of freeplay (between the sprockets again).
Does this make sense? most manuals give you a picture to show what I'm trying to describe, usually in the maintenance section.
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
craacker
Sep 9, 2015 04:32 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
goosemasterkl
Aug 23, 2015 11:36 AM
