Performance Carb. For Wolverine
Old Jun 26, 2004 | 04:43 PM
Webb's Avatar
Default Performance Carb. For Wolverine
Does Anyone Know If They Make A Performance Carb. For The Wolverine?
Old Jun 26, 2004 | 11:10 PM
SpDdEmOn's Avatar
Yeah they do. What kind of performance are you wanting out of your Wolverine? Any carburetor for a Warrior or a Raptor 350 will fit on a Wolverine as well. Just tell me how fast you want it, and ill tell you what to do to make it that way.
Adam
Old Jun 27, 2004 | 05:11 PM
Webb's Avatar
Well its an `02 wolverine everything is stock so which will give me the most top end as of your knowledge thanks
Old Jun 27, 2004 | 11:58 PM
95wolv's Avatar
The Edelbrock Quicksilver for the Warrior will work, just remember that unless you go to a manual clutch kit, stay with a carb with an accelerator pump,or it will bogg bad on the bottom end,because of the auto clutch taking a little more time to rev up. I have thought about a different carb myself, Speeddemon, so if you know of a good aftermarket carb ( with accelerator pump), let me know, too.
Old Jun 28, 2004 | 12:03 AM
Webb's Avatar
hey 95wolv did u pick up some speed from your edelbrock Carb. ??
Old Jun 28, 2004 | 12:15 AM
95wolv's Avatar
I don't have a different carb, just know about the Edelbrock, at 409 bucks, it's a little spendy for me !!!
Old Jun 28, 2004 | 12:17 AM
Webb's Avatar
WOW yes it is a little to much to spend
Old Jun 29, 2004 | 03:07 AM
SpDdEmOn's Avatar
95Wolv - My 36mm Race carb has the accelerator pump, and I love it. The 446 loves it as well. It runs so much better with it on there than it does with the stock carb. You can buy it from Mickey, but its $435, so if you didnt like the $409 for the Edelbrock then I dont think you will like this price much better. To get any of the carbs with the accelerator pumps you are going to pay about $400, however you can buy the same model carb without the accelerator pump for a few hundred less. If you want a race carb and dont want to pay $400, then call Mickey and get the carburetor that I did without the accelerator pump.
Webb - As for top end, the carb on my bike makes a pretty big difference over the stock one. I originally had a 36mm carb to start with because I have a 95' Wolverine and it made a difference over that so, you will see an even bigger difference over your stock 34mm. Be sure to jet it properly, and have fun.
Old Jun 30, 2004 | 05:22 PM
Webb's Avatar
Thanks
Old Sep 1, 2004 | 10:38 AM
Quadusmaximus's Avatar
If you do a search for "yamaha warrior carburetor " on ebay, they got edelbrock performance series carbs for warriors
at $350.00.
I called edelbrock to find out if these carbs would work on a wolverine
but they didn't know.
Anybody else know??
96' wolverine
warn winch
