200 main jet????
Old Jun 29, 2004 | 03:05 PM
Zeakman's Avatar
Default 200 main jet????
MY bike has been backfiring and hesitating alot, so i took the carb off and i was lookin at it and i took the main jet out and its a 200. I was saying to my self that sounds really big maybe thats why its running like sh*t. Guys help me out here, I have a 99 400ex with white bros R4 pipe, k&n air filter, what size jet should i be running.
Old Jun 29, 2004 | 04:37 PM
dragracer789's Avatar
What kind of carb? ifs its a kehien then wow thats huge! But it shouldnt make your bike backfire. That would mean its to lean. If its really a 200 it should make it sputter and not run smooth, and also will make it hard to rev hi. Im not sure but I think the stock 400ex jet is in the 150s, or low 160s
Old Jun 29, 2004 | 05:06 PM
chazekxt's Avatar
my buddy has 04 400ex with white bros e2 slip on and k a n filter and a 170 main jet the stock jet is a 148 on the 04 s tri a 165 to a 170 should be good.
Old Jun 29, 2004 | 05:08 PM
hondabuster's Avatar
The main jet wont effect backfiring and hesitation. Sounds like the mixture screw is too lean. I think that its too big also, (200 main).But the backfiring and hesitation is a separate issue from the main jet.
Old Jun 29, 2004 | 05:10 PM
Acually no if your main OR pilot circut is to lean it will back fire. I know what you mean though, if the main is to lean and you dont rev it up enough so the motor is running on the main then it might not backfire but if its lean it can definetly back fire.
Old Jun 30, 2004 | 11:26 PM
cals400ex's Avatar
with the R4, K&N, and the air box lid ON, i would put in a 152 or 155 Keihin mainjet. try turning the fuel screw on the bottom of the carb out 3 turns from lightly seated. the fuel screw should fix the backfiring problem.
Old Jul 5, 2004 | 04:30 PM
450r's Avatar
i run a k&n filter with no air box lid,fmf power bomb header and power core 4 pipe with a rev box on my wifes bike and we run the fmf jet kit as told with the exception that i like to run the main about 10 points (175-185) higher and run a hotter plug.
MooseHenden
Family ATVing Photos
Oct 5, 2015 08:14 AM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
