someone has durablue axle on v-force, right???
Old Jun 29, 2004 | 09:06 PM
higgsV's Avatar
Default someone has durablue axle on v-force, right???
remember reading about it, did a search, found nothing.
NOW i need an axle. anyone have any info? thank you.
Old Jun 29, 2004 | 09:20 PM
trailride's Avatar
I havr a durablue axle on my V. i got it from rockymountianatv.com I got the eliminator standard. I would get the 2+2 axle if i did it over. Both are the same price ..It was $300.46 to my door.
Old Jun 30, 2004 | 11:36 PM
higgsV's Avatar
sweet, thanx so much for the reply. i was bummed 'cause i thought it would be around $500. i have a couple of more questions if you don't mind: what are you running for hubs? i seem to remember someone having problems getting the bearings or something like that.............did you have any problems?
Old Jun 30, 2004 | 11:48 PM
trailride's Avatar
I have the stock hubs on the axle, and i used the stock bearing. The only problems you will run into is getting the nuts off for the hub, and the bearing nut. This bearing nut is HUGE.. I work at a machine shop and we didnt even have a wrench to fit it. We used a 36" pipe wrench. This retainer is set at 168ft lbs . Thats tight. The bearing is kinda stuck on the factory axle but with a press it came right off. Im not saying you need a press. You could use a fork shaped piece of wood and tap it off with a hammer. The bearing will slide right back on the new axle with no effort. Now to tighten the retainer back, i used a large vise and some brass shimstock sheet so it wouldnt scare the new axle. I pretty much just got the nut as tight as i could.
P.S. there are 2 set screws on the bearing retainer nut, these things are tight as hell too. Be sure to use a allen driver on these . The kind you put on a ratchet.
If you have any questions feel free to pm me..
Brent
Old Jul 1, 2004 | 12:23 AM
MickeyDunlap's Avatar
I have a durablue I will sell if you want one.
Old Jul 1, 2004 | 10:20 PM
higgsV's Avatar
mr dunlap, details please?
trailride, thank you for the help.
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
1000gade
Sep 9, 2015 04:41 PM
bmark0610
Sep 7, 2015 09:42 PM
snowolson
Aug 31, 2015 03:51 PM
toonces
Aug 5, 2015 05:55 PM
