gett me headed in the right direction with my jetting?
Old Jun 30, 2004 | 07:17 PM
Carmelo15's Avatar
Default gett me headed in the right direction with my jetting?
i want to remove the airbox lid, i currently have a full exhaust, k&n what jetting should i do? also the higher the number on the jets the richer or leaner? should i change the pilot change or change the needle clip position. i currently run a 162 main jet. please aim me in the right direction.
Old Jun 30, 2004 | 07:21 PM
pinheadedjoker's Avatar
the higher u go the richer it is.. needle clip should be on or around the 3rd postion id go up prob 5 jet sizes at least if u take off ur lid maybe more.. give that a try and then keep richening it up till it bogs then drop it till it runs perfect [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 30, 2004 | 07:29 PM
Carmelo15's Avatar
ok well my gytr jet kit only came tyhe the 165 main jet and that is the highest should i try that?
Old Jun 30, 2004 | 07:30 PM
Carmelo15's Avatar
also what is the deal with turning hte screw 1/8'' and stuff like that what exactly are you turning? should i change my pilot jets? or maybe my clip to make up for my 165 jet not being high enough?
Old Jun 30, 2004 | 07:32 PM
on the bottom of the carb not in the flaot bowl but outside on the bottom there is a flat headscrew tighten it allthe way tehn turn it left about 2 1/2 turns thats ur fuel air screw.. and try the 165 see how it runs.. do a plug check with a new plug(there is many upon manny of ways to do this in teh search feature) and if u need to richen it up then go buy a bigger jet from a shop [img]i/expressions/face-icon-small-smile.gif[/img] or order soem online [img]i/expressions/face-icon-small-smile.gif[/img] alrighty
Old Jun 30, 2004 | 07:36 PM
also the lower u put the clip on the needle the richer it will run but mainly here is how it works the pilot jet should be fine the way it is.. it controls your idle gas , the needle is idle to mid range.., and main is 3/4 to full throttle..
if its not rich enough with teh 165 then put the needle position clip down to richen it..
i dont know how the yfz is.. but im assuming its like the raptor.. if so you can tell if its lean by putting the choke on a little bit.. if it runs better that way then its running lean also watch the tail pipe.. clean it up with a rag then run it and if its real sooty with black stuff when ur done ur running way to rich but if its just a little sotty then its prob just right if there is nothing there then ur prob running a bit to lean.
Old Jun 30, 2004 | 07:38 PM
Carmelo15's Avatar
is it hard to disassemlbe and take oput my carb? im kinda hesitating.
Old Jun 30, 2004 | 07:43 PM
As far as the yfz is concerned.. i dont know whats involved but im assuming its similar to the raptor. and if it is then its not that hard. for the raptor all you do is take off the fornt plastics and then take off the gas tank take out 4 screws for the carb boots then flip the carbs undo 4 bolts a piece for the bowls then unscrew the jet then put it back in and reassemble..
if it were me i would do it, it will be a good thing that will give you power and its not to expensive.
Old Jun 30, 2004 | 07:49 PM
Carmelo15's Avatar
thanks for all the help man, i wish you were beside me so you could help. i will try it out wish me luck, it will be the first time i attempt to jet my quad...
Old Jun 30, 2004 | 08:40 PM
Carmelo15's Avatar
Ok pin, i got all the plastics off and i unbolted the gas tank but how do you unplug the gas line from the carb? its on their so tight or it like glued on?
ghost civic
Jan 15, 2020 07:43 AM
neo27ny
Aug 24, 2015 02:02 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
