please help
Old Jun 30, 2004 | 09:30 PM
Polaris500HO4x4's Avatar
Default please help
went to the dealer to have him fix my primary clutch now i brought it home and has a creeping problem and when i hold in the brakes the belt squeels. whats up with this thing
Old Jun 30, 2004 | 09:37 PM
thewayout420's Avatar
Default please help
the belts to tight..
Old Jun 30, 2004 | 10:28 PM
Hozed's Avatar
Default please help
sounds like you should give your dealer a call back!!!
Old Jun 30, 2004 | 10:39 PM
predatordude's Avatar
Default please help
they probably didn't align the clutches, there is a special tool to align the clutches, your belt is catching on the drive clutch and causing it to creep, they may need to shim the clutch also.
Old Jul 1, 2004 | 12:56 AM
Default please help
i watched him put on the belt and he ripped off the old one and kinda shoved the new one on and turned the clutch to get it to ride on the secondary clutch.
will it hurt anything if i ride it this way
Old Jul 1, 2004 | 01:05 AM
Whitedog's Avatar
Default please help
It shud go on fairly tite. if you wanna check it lay a strait edge on top of the belt, from the center of the primary to the center of the secondary. Now push down on the belt fairly firm in the center and measere the distance. from the strait edge to the top of the belt. It should be 1 1/8
Old Jul 1, 2004 | 01:07 AM
Whitedog's Avatar
Default please help
Sorry didnt read the rest. may burn ur new belt up.
Old Jul 1, 2004 | 01:09 AM
Default please help
well im really not to worried about the belt. but ill have to take it back in sometime then tomorrow.
thanks again guys for your replys i appreciate it
