V FORCE Bigger Carbs
Old Jun 30, 2004 | 11:54 PM
VNASTY's Avatar
Default V FORCE Bigger Carbs
What would 39mm carbs do for a stock 700 motor? I think the ones on a Yzf-450 will fit with a little work.Will it have more power all the way around or top or bottom. Just had a brain fart.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jul 1, 2004 | 12:07 AM
KawiTuner's Avatar
they would work great, good luck with the throttle cables
Old Jul 1, 2004 | 12:18 AM
VNASTY's Avatar
I thought about that if it would be hard to get them to open at the same rate.I will have to look on the net for custom carb set-ups.
Old Jul 1, 2004 | 01:46 AM
sandRappy's Avatar
You could always try a banshee cable to pull both carbs. It has a place in the cable that connects the two individual cables together into a single cable, which then hooks up to the throttle housing. Heck it might even be the same threads for the throttle housing.
Cole Hadden
Jun 15, 2025 09:05 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
