banshee ?
Old Aug 10, 2000 | 12:18 AM
banshee1stquad's Avatar
when i get on the throttle it almost sounds like the motor is missing(breaking up) until it hits the powerband then all hell breaks loose is that normal
THANKS FOR YOUR HELP!!!!
Old Aug 10, 2000 | 09:53 AM
jg47588's Avatar
Every Banshee I've ridden has performed that way, including my '99. I just put FMF pipes and jet kit in it, and it sounds even worse at lower RPMs because you can hear it better. I've spoken to the local dealer, and they tell me that some quads are just designed that way. I had a Polaris Sport 400 that ran the same way. I don't believe you have anything to worry about.
Old Aug 11, 2000 | 09:37 AM
joey1's Avatar
Your Banshee is supposed to be crisp from the bottom of the powerband to the top, my bike is crisp all the way through, if someone tells you otherwise they are wrong, your jetting is off, it sounds like your bike is running too rich on the low end, check your manual about which jet controls 1/4 to 1/2 throttle, I cant remember off hand, but your bike definitly needs some minor tuning.
Old Aug 11, 2000 | 10:02 AM
BansheeBill's Avatar
1/4 to 3/4 throttle is primarily handled by the needle setting. Try raising (enrich) or lowering (lean) the needle setting until you get proper performance.
Old Aug 11, 2000 | 11:51 AM
WyoRider's Avatar
No, that is not normal. Mine did the exact same thing when I bought it new and I believed that it was normal. I was able to correct it by replacing the stock reeds with Boyeseen reeds, K&N filter and adjusting the idle circuit mixture. I didn't need to change the pilot jet or move the needle clip. How much improvement for reeds/filter/idle mix individually I don't know but now it is very responsive from idle up. There is still a lack of low end grunt, but it doesn't bog at all.
Old Aug 13, 2000 | 12:49 PM
WyoRider's Avatar
Also...... I removed that POS TORS last week because I was having a problem with it dying out for a second when I moved the throttle from idle forward. I would give it the gas and nothing would happen for a second. I rode this weekend and it doesn't do that anymore with the TORS disconnected. Well, it was fine before I did an endo into a large tree... Ouch!
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
