How do I hook up my choke cable to a 39PWK
Old Jul 3, 2004 | 11:08 PM
EAB's Avatar
EAB
Default How do I hook up my choke cable to a 39PWK
I have a 39PWK carb, and the black plastic choke doodad that threads into the carb is a different size than the brass thingy on the end of my choke cable [img]i/expressions/face-icon-small-sad.gif[/img] . Is there another brass thingy available to adapt to the PWK?
Old Jul 4, 2004 | 12:35 AM
Bubba297's Avatar
When I got the HPD setup, it had an adapter for the cable. You might be able to get one from Rick or HPD by itself. It was just a small brass fitting.
Old Jul 4, 2004 | 12:54 AM
modquad's Avatar
Or you can do like I do, and just have the manual **** on top of the carb. The less I have routed to the handlebars, the happier I am. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 4, 2004 | 03:13 AM
EAB's Avatar
EAB
Modquad, I thought about keeping the original choke **** on it (and I still may) but the PVT vent tube is in the way when I reach down there .....hmmm, the vent seams to have fallen off of yours[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 4, 2004 | 11:26 AM
modquad's Avatar
The 90 degree vent on my Sport is actually a molded elbow from the Grizzly corp.. It's originally meant for dust collection systems in wood working shops. As long as you have the latest and great cover with the larger opening, it fits nice. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 4, 2004 | 02:19 PM
braveops's Avatar
my 39 pwk came from a sled and the brass fittings fit my cable i think mine was off a 600 or 700 polaris look at i think it is partsland they show the carb
Old Jul 4, 2004 | 07:35 PM
scramblered's Avatar
i do know that the 39 mm keinhin carbs into the 600 and 700 big block domestic twin polaris was not the same as the scrammy must use in the race mod combo,totally different use.
Old Jul 5, 2004 | 12:19 AM
braveops's Avatar
so you mean i cant use the 39pwk from the sled???
Old Jul 5, 2004 | 09:34 AM
if you look at the way the sled carb are mounted through you'll find isn't the same as the quad racing carb.i don't think the sleds
carbs are pwk racing carbs,and i do know cauze i had a '98 xc 600 domestic twin back then when they first released them,brand new,trouble frees machines.
Old Jul 5, 2004 | 11:48 PM
braveops's Avatar
ya i t does look like the same as your 98xc 600. it is a flat slide carb the only diffrence i can see is the idle and mixture is on the wrong side my stock choke cable fits on i just need to get a clamp and i will be ready to play with the jetting
