Wheelies on Bruin 350
Old Jul 5, 2004 | 11:21 PM
Rwwertz's Avatar
Default Wheelies on Bruin 350
How if you can, do wheelies on a bruin?
Old Jul 6, 2004 | 01:41 AM
dfdsfd's Avatar
lol prolly stand up and push ur feet ont he rear racks and pull up in 1st gear.
Old Jul 6, 2004 | 10:50 AM
BigScary's Avatar
no 1st gear........it is an automatic
and you can wheelie if you stand on the back and push down hard enough...........it is very hard though........
Old Jul 6, 2004 | 09:55 PM
UltimateAussie's Avatar
you can get the bruin in semi auto too
Old Jul 6, 2004 | 10:05 PM
RoscoePW's Avatar
you cant get the bruin in semi auto.... you can get a wolvy , but there is a big diff.
Old Aug 25, 2004 | 01:49 AM
ProComp's Avatar
Good luck. Tried all night in rack deep water and no luck. Guy on a Rancher, no problem. The Bruin lacks low end grunt to pop up the front.
ProComp
Old Aug 25, 2004 | 02:38 AM
woody431's Avatar
I can get a wheelie on pavement, a small one, but they come up. I just have to get the tires a little hot/sticky and it'll pull them up. I definetly can't just pull up a wheelie..I'm a twig, 6'4 150 lol my friend who is 6'4 230 can barely even get the front wheels up. So i'd say you're prolly SOL.
Old Aug 26, 2004 | 08:50 PM
thebruin's Avatar
you have to go on a hil with a peak on the top go slow up it then give er at the peak and pull up and push down on the back rack with your feet. i can do it for 75 ft
Old Feb 19, 2005 | 09:01 PM
Sammer01's Avatar
What you do is lean over your tank with the front brake on get ur tires goin good and then slowly put ur feet on the back rack push down and let go of ur brakes and the front end will pop up for you or if you want to wreck the gears you can always rev he engine then slip it into forward not so good though.
Old Feb 19, 2005 | 10:23 PM
sleepy69's Avatar
if u got the bruin that has 2 wheel drive u can do it easily..... u can do it on the wolvy 2.. i can do it on mineby puttin my knee on the back of the seat close to the rack and hold up on the shifter rev it up and let go of the shifter and pull up like hell.... it easier and funner wen somone else is on the back with yeah
