400ex airbox lid
Old Jul 7, 2004 | 03:21 PM
SpeedDemon13's Avatar
Default 400ex airbox lid
if i took of the airbox lid off of my 2003 400ex it would add power right? what kinda power would it add? torque or top speed? also do i just unclip it and leave the clips there? i just put the lid somewhere else and then just put the seat back on?
Old Jul 7, 2004 | 03:25 PM
400eecksRider's Avatar
wont do much of anything except maybe make your engine bog. Add a slip on, rejet, a new K&N filter, then remove the lid. They all compliment each other. Just one change wont do much by itself.
Old Jul 7, 2004 | 04:13 PM
cals400ex's Avatar
coming out of a corner you may have a tad bit more torque given you rejet. if you don't you are just running the risk of hurting the motor from a lean ratio. don't expect more top speed.
Old Jul 7, 2004 | 04:18 PM
hondarider300's Avatar
i have heard that u will actually lose power because the air will slow down. but if u leave it on it will force the air to rush through (making more power then slow air). im not sure if this is true and no i dont run a lid and it seems to have more power without (rejet) but i also have a more high flowing exhaust pipe and a high flow filter.
Old Jul 9, 2004 | 03:30 PM
cals400ex's Avatar
yeah, i have tested with this before. from physics, the more volume means less velocity. the lower volume gives greater velocity. however, i really could never tell a difference in power.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
mbriggs
Sep 13, 2015 10:47 AM
