A-arm`s Camber ?????
Old Aug 10, 2000 | 10:21 PM
Lucis's Avatar
What setting do you have the camber set at. I have my set stright up and down. But i would like to know if i should set it 1/2 inch in. whats best to set it at. This is for MX track riding.
Old Aug 10, 2000 | 10:41 PM
Skunky's Avatar
I use a 3 1/2 degree tilt
Old Aug 10, 2000 | 11:22 PM
Lucis's Avatar
Skunky
what do you have your toe set at.
also what did you use to set your toe, what method?
Old Aug 11, 2000 | 01:18 PM
Skunky's Avatar
I use pritty much 3 1/2 degree's all the way around.. 3.5 toe-in 3.5 camber 3.5 caster. That way when you hit the turns and grap gops of the front brake the front tires will stand up straight to fly you through that corner. Same with jumps with the camber in 3.5 and the tilt 3.5 when you land the tires will line up straight and stand up straight. Most MX'ers run 3.5 and Desert Riders run 7 degrees.
The tool I uses is a caster/camber gauge with magnetic adapter. It is made by longacreracing. There web site is www.longacreracing.com under browse catalog/frontend setup. It is 150.00 the best thing to do is for you and a couple of buddies to pitch in on it since you will not use it much... After all is set i use the string/spring method to verify measurements...
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
XxS0ccerstarxX
Aug 31, 2015 04:47 AM
XxS0ccerstarxX
Aug 27, 2015 07:40 AM
musselmark
Jul 17, 2015 02:40 PM
