high revving, constant plug fouling
Old Jul 9, 2004 | 02:04 AM
whyisnicknamerequired's Avatar
Default high revving, constant plug fouling
My 87 zilla revs very high at times for no reason, i have heard that these are commmon and are possibly air leaks, My zillla also fouls plugs alot and the guy i bought it from just said that it was a race quad and that it needs to be run wide open or they will foul, i thought maybe he might have been putting too much spectro into the mix well if anyone has had any of these problems it would help if i knew what to do about it. it has a few mods that i know of over forty and a fmf pipe maybe more i dunno yet.
Old Jul 12, 2004 | 04:38 PM
guess no one knows anything about this....
Old Jul 12, 2004 | 05:41 PM
Aaran's Avatar
just for the he!! of it clean out the carb. check inside the carb that the float isnt stuck and some thing isnt holding the choke element inside the carb.
Old Jul 12, 2004 | 10:51 PM
I have allready done that clean the carb and air filter but it came with a 420 main jet would that cause the problem (im going t6o get new jets shes runing very lean).
Old Jul 12, 2004 | 11:12 PM
Aaran's Avatar
could be
Old Jul 12, 2004 | 11:19 PM
donzilla's Avatar
as far as the reving it does sound just like an air leak . prolly at the back of the cylinder or around the intake . check to see if the plug is the right one . b8eg
Old Jul 13, 2004 | 12:28 AM
THe plugs that cam with are the NGK R BR9ES.....ill buy the other ones just to make shure that its not just the plug
Old Jul 13, 2004 | 12:31 AM
i need to go back to highschool i cant spell
Old Jul 13, 2004 | 12:35 AM
Schmoyer1's Avatar
Can you get this thing to idle?
My 250 would rev irratically at times for no reason and no matter how hard I rode it the plugs would eventually foul. My plugs always had some carbon build up on them. Turns out it was time for a rebuild....
Old Jul 13, 2004 | 12:40 AM
THe guy i got it from said he just had it rebuilt. yea it will idle thoe...i took it over to a budy of mine and he went through the carba dn what not and he git her to run about perfect then when i got it hame she ran fine for awhile then started that bs agian
