Should I rejet?
Old Jul 9, 2004 | 10:19 PM
FireFighter69ca's Avatar
Default Should I rejet?
With the Nyroc mod and the DG3 module, should I rejet my bike, and if I do have to, what do I jet it to?
Old Jul 9, 2004 | 11:27 PM
nyroc's Avatar
You need to test the jetting yourself.
My guess is you will need one main size richer, and about .050 shim under the needles.
Old Jul 10, 2004 | 06:11 AM
cartman308's Avatar
pull your plugs. Chances are you are lean. This would cause a white colored plug. If that's the case go up one jet size. most people seem very happy with 142f/145r combos with the type of mods you list. Do a plug check before you fool with the jets.
Old Jul 10, 2004 | 10:53 AM
mastrblastr's Avatar
Elevation plays a huge part as well, but Nyroc and Cartman gave you good advice. A plug read will tell you where you ought to be. I'm running 145/148 at about 4000 ft and have had good luck with this setup. I also have a custom intake snorkle, airbox mods with a Unifilter, and a modded muffler. Got tons of jam.
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
cSchwartz
Jul 9, 2015 02:43 PM
Bm400ex
Jun 22, 2015 09:16 AM
quad_300ex
Jan 23, 2000 10:17 PM
