How do you adjust the float bowl in a honda recon?
Old Jul 10, 2004 | 02:01 PM
RABDAB's Avatar
Default How do you adjust the float bowl in a honda recon?
I posted about a running problem with the honda recon and a member said to adjust the float bowl.
Thanxs to any who can help.
Ryan
Old Jul 11, 2004 | 06:37 PM
95wolv's Avatar
They probably meant adjust the float height in the fuel bowl, you take the carb out,take the 4 screws out of the bottom and bend the arm on the float that sits over the needle and seat, if you haven't done this before, get someone to help, or get a manual, if you set it wrong, it can really mess it up. Also, some floats are one piece, with no adjustments, if there is no metal arm to bend and it's all plastic, leave it alone. Just a question, what is the problem that you need to check the float.??
skinnyr6
Aug 25, 2023 02:18 AM
metal249
Jul 28, 2015 09:35 AM
hondarider1234
Jul 21, 2015 11:53 PM
Aitch
Jul 21, 2015 09:40 PM
MNatv89
Jul 7, 2015 11:36 AM
