trx450 hrc kit should i get it?
Old Jul 11, 2004 | 05:21 PM
alex1212's Avatar
Default trx450 hrc kit should i get it?
my dealer down the street has some of the hrc kits for the trx450's..i know i need more power outa my 450 do you guys think is hould go get the kit? or is it a waste of money
Old Jul 11, 2004 | 05:28 PM
budman07's Avatar
get it! i have only heard good things.
Old Jul 11, 2004 | 05:30 PM
scrambler123's Avatar
If i was you i would just get a full exhaust and and cam.
Old Jul 11, 2004 | 06:22 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
See the August issue of ATV Action, pg. 62. There is a before and after dyno. Below about 5,500 rpm there is little difference with or without the kit. Above that, THE DIFFERENCT IS DRAMATIC........43.8 hp @ 8,500 rpm, vs the stock max of 33.1 hp @ 7,250 rpm. That is over 10 hp, and with the stock pipe! I would expect even more with an aftermarket pipe. Sadly, they do not include the torque curve.
So, all the gain is at the mid to high end.
Old Jul 11, 2004 | 09:20 PM
450r's Avatar
for the money this kit is the best thing out there. unless you plan to buy an after market exhaust you will not see much improvement in the low end . to counter this just run a 13 tooth sprocket and there you go. keep in mind that if you plan on running exhaust ,then save your money and dont bother with the kit. the only stuff im still running out of the kit are the cam, vents and neddle.worth 300 bucks? ,no.you can play with the numbers a bit but they're pretty close . dont do what i did ,i bought the kit ,jet kit , filter ,full exhaust =$840 i could have saved about $300 if id got the after market cam to begin with and the exhaust came with jets. you can get the neddle at honda.
kit w/o exhaust $ 200-300
kit w/ slip on $400-500
kit w/ full exhaust $600-?
after market cam $125
jet kit $45
filter $45
slip on $200-?
full exhaust $400-? some exhaust 's come w/jetting
XxS0ccerstarxX
Aug 27, 2015 07:40 AM
QuadAddiction
Nov 3, 2005 01:21 AM
Anto
Oct 20, 2005 12:01 AM
warriorboy22
Jan 24, 2005 11:11 PM
ORANGE400exRACER
Nov 27, 2004 09:30 PM
