Is ther an upgrade for polaris 90 battery?
Old Jul 11, 2004 | 07:44 PM
dunesled's Avatar
Default Is ther an upgrade for polaris 90 battery?
I've got a scramblr 90 for my daughter and I hooked up a small headlight and taillight on it. Well as you can guess the battery does'nt last to long. It's alittle thing, and I'm wondering if there is a better one for it that will fit in the same space?
Old Jul 11, 2004 | 07:52 PM
spike99's Avatar
Not too sure if there is a heavy duty battery for the Scrambler 90. Even if you did install a heavy duty battery, you may still have the same "dead battery" problem. On the Sportsman & Predator 90, their stator system outputs 70 watts (at max RPM). If you divide by 1/2, its charging system can support a 35 watt bulb and have some left over to charge its battery. As a suggestion, you may want to decrease the wattage in your customized front light to a 20 to 35 watt bulb. On our Pred-90, we have a 35 watt bulb. Our 35 watt bulb allows our unit to hold a charge and lights our trail (daytime running lights & the odd time we get caught in the dark) at the same time.
Hope this 20-35 watt bulb idea helps on your Scrambler.
Mattius
Jul 11, 2015 10:44 PM
tweeder
Jul 5, 2015 01:57 PM
bikedad3
Jun 29, 2015 08:58 AM
bradleyheathhays
Jun 23, 2015 01:30 AM
Predator_500
Jun 13, 2015 03:01 PM
