won't idle
Old Jul 12, 2004 | 12:24 AM
Flashover's Avatar
Default won't idle
I was wondering if anyone can help??? my honda atc 110 won't idle unless the choke is on.
Has anyone had this problem???
I have a carb kit ,, but not sure that is it,,, it seams like a vac leak to me.
But i sprayed with carb cleaner and can't find a vac leak.
Thanks for any help
Old Jul 12, 2004 | 04:03 AM
MY86ATC350X's Avatar
Default won't idle
LOOKS LIKE THERE AINT ENOUGH FUEL GOING THROUGH YOUR JET OR MABE YOUR JET IS CLOGGED OR YOU AIR FILTER IS CLOGGED. HAVE YOU TRIED TAKING OFF THE CHOKE WHEN YOUR ATC IS WARM. REMOVE YOUR CARB AND OPEN THE FLOAT BOWL FLUSH IT OUT CLEAN IT REALLY GOOD WITH CARB CLEANER ACTAULLY CLEAN THE WHOLE CARB INSIDE AND OUT IT MIGHT WORK AND REPLACE YOUR AIR FILTER. AND IF THAT DOESNT HELP GO FOR THE REBUILD KIT.
Old Jul 12, 2004 | 01:15 PM
ThrashAndCrash's Avatar
Default won't idle
Just a little hint when looking for a vac leak....make sure the stuff you are using will burn!!!!!!!! alot of the crap they sell today is "safe" and will not burn, making it worthless for leak checking!
Old Jul 12, 2004 | 11:41 PM
Flashover's Avatar
Default won't idle
I used regular carb cleaner and propane to ck for the vac leak , but no good.
I also tore the carb down and soaked it in carb cleaner(the type u put car carbs in)
I blew thru every jet i could find.
The air filter looks ok ,, but i think i replace it anyway.
As far as being warmed up , it won't idle hot or cold unless the choke is on.
Another insight ,,,, the bike runs fine at off idle with the choke off.
Could it possibly be a valve adjustment problem?? ( i bought this bike form another person and he never did any thing to it)
also where do i get the air filter if the air box is removed???
hope this helps
Old Jul 13, 2004 | 12:53 AM
Default won't idle
are u sure that the carb is for the bike or is it another one. try to get another carb and try it. youll find one at ebay just keep your eyes open. ill try to find some info on your 110 to make it work. something might be wrong
Old Jul 13, 2004 | 11:35 PM
Flashover's Avatar
Default won't idle
yea it be the original carb for the trike,,, the guy i bought it from bought it new from honda and he used it for hunting,,, and then his oldest boy wanted to ride it and he thought it was time to sell...
Anyway i cked the valves today and they be ok.
Also can i get the lifter plugs from the dealer,,, i kinda broke one today????
Old Jul 14, 2004 | 03:37 PM
Default won't idle
yea i think you could. try going to www.bikebandit.com right there you can find any OEM part for your 110 and 3 wheelers part if it its not discontinued.
Old Jul 16, 2004 | 12:04 AM
Flashover's Avatar
Default won't idle
found the part i needed,,, the polaris dealer had it.
what is the point gap for the 110?? and what type of oil do i neeed to use to change the oil???
Old Jul 16, 2004 | 04:14 AM
Default won't idle
ok to let you know for most bikes honda recomends •Honda 10W40• i dont know what point gap it has to be but try to figure it out i have a 1976 honda XL350 witch i didnt know what the point gap was so what i did i set the point gap really close and from there i would be seperating it apart little by little. so i whould listen to the engine sound and backfire. and i left it to see which sounds better.
Old Jul 19, 2004 | 02:18 AM
pondrunner's Avatar
Default won't idle
you could try adjusting the mixture screw on the carb. thats what was wrong with my bros. screw it out about 1.5 to 2.0 turns and if its idel enough to run adjust it to were it will sound right. but you might have adjust your idel screw a little if you messed with it.
