Kawaski KV 75 how I adjust the oil injection pump?
Hi, i was wondering how do I adjust the oil injection pump, there is a adjuster just like the clutch cable and stuff like that. I don't know where teh adjustment should be. Thanks
You adjust the cable length by turning the adjuster you found. There should be some marks on the pump and the arm that the cable is in that should line up when it is at full throttle.
craacker
Sep 9, 2015 04:32 AM
2001, adjust, adjusting, adjustment, bypassing, cable, clutch, idling, injection, kv75, kv75adjusting, modifications, oil, pump, throttle
