Compression
Old Jul 12, 2004 | 05:47 PM
twinrider's Avatar
Default Compression
I have a 1995 klf 400 bayou... like to know what the compression should be ?
Old Jul 13, 2004 | 08:19 AM
AlaskaBayouGuy's Avatar
Default Compression
well what is it now?
Old Jul 13, 2004 | 02:06 PM
twinrider's Avatar
Default Compression
AlasakaBayouGuy...have not checked the compression yet / Just want to know what it would have been
When it was new So when I check it to give me some idea of what it has lost if any ... thanks for you reply
Old Jul 14, 2004 | 03:27 AM
Default Compression
i would say that static compression of your engine should be between 100 - 120 - for a much more accurate compression you need a differential pressure tester. this type of tester also known as an aviation type has 2 guages, and takes shop air to operate. if interested on this tester i can send you some specs on how to build one. either way, testing is most accurate when the engine is hot and not sat too long after shutdown.
Scooter's Shop
Oct 9, 2015 02:09 PM
CosmoM
Sep 21, 2015 04:57 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
