NEED help on how to set cam on 85 200X motor?
Old Jul 12, 2004 | 05:52 PM
MY86ATC350X's Avatar
Default how to set the cam on 85 200X motor?
I have a 1985 atc200x motor im replacing the top end gaskets i removed the whole top end. now i set the whole thing back together. i want to know how the camshaft has to be set. this is the way im doing it im setting the piston to top dead center and i put the cam back on, then i put in the cdi pulse unit on to set the cam. i put the cdi on the fireing mark. so the engine is actually in combustion point. so am i doing it the correct way? or is there another way. please help. would apreciate it alot.
85 ATC200X motor
Old Jul 13, 2004 | 12:29 AM
KNOWSALOT's Avatar
The Facility
Default NEED help on how to set cam on 85 200X motor?
Sounds like you have it correct to me.
Lobes down and the pin to locate the advancer is about at the 10-11 o'clock postion.
This will put the mark on the advancer rotor at 12 o'clock at TDC.
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Whitelx1
Oct 2, 2015 10:55 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
