trail pipe problem!!
Old Jul 13, 2004 | 04:23 AM
scrambler123's Avatar
Default trail pipe problem!!
Has anyone else had a problem with their trail pipe rubbing on the metal of the recoil housing mine has ate away a groove of the housing and has also taken a little metal from the pipe i'm worried about it going all the way through the pipe since it is fairly thin metal.
Old Jul 13, 2004 | 04:20 PM
jimmypsp700's Avatar
Mine has a good half inch to an inch clearance.
Old Jul 13, 2004 | 06:42 PM
BeltDrive's Avatar
I also have plenty of clearance.
Old Jul 13, 2004 | 06:54 PM
hmmm that doesn't make too much sense.
Old Jul 13, 2004 | 07:14 PM
tbsleeper's Avatar
maybe because it was lowered it lowered the front of teh pipe and the back is still the same??or the engines not in right?
Old Jul 13, 2004 | 08:01 PM
lowering the bike would have nothing to do with it. Its not because the motor isn't in right because it's rubbed since i put it on before i ever took my motor out.
Old Jul 13, 2004 | 08:11 PM
tbsleeper's Avatar
ok then wat do u want us to do?? call hpd it is there pipe we didnt make it so dont take out ur anger on us
Old Jul 13, 2004 | 10:10 PM
braveops's Avatar
i had the little pipe off the head on backwards and it was giving me problems
Old Jul 13, 2004 | 10:12 PM
tbsleeper i'm not angry at all
Old Jul 13, 2004 | 10:17 PM
Scrammy400's Avatar
123 do you have to big or the wrong rubber stopper on the top of the pipe near the header. It could be pushed down to far causing you recoil problems. Do you have a smaller spring to tie the front of the pipe to the frame? Mine was way to long and did nothing at all. Swapped it out and sprung it nice and tite.
My 2 Cents
