What size jets for 250R
Old Jul 13, 2004 | 06:59 PM
rdnred's Avatar
Default What size jets for 250R
I have an ESR exhaust ordered for my 86 250R, and was wonderin what size jets would be best for it. Where i live we're about 2600 feet above sea level i usually run mid, or high test gas and use Motul T2 oil (synthetic). It has a Kehein carb on it now, and i am not sure wether it is pre-jetted or not; because it was on it when i got it. Also i was wonderin if V-Force 3 reeds for it would help it out any. I have heard people talk about them but i don't know anyone that his them in their quads.
Thanks
Old Jul 13, 2004 | 08:07 PM
pimp250r's Avatar
Not sure about the jetting.
For reeds, G3 Power Curve Reeds here - You will also need to rejet and probably regear for these.
Old Jul 15, 2004 | 12:34 PM
Dan250race's Avatar
You are going to have to give me a little more info
- is it bored
- what size in the carb
- what jet does it have now
- what pipe is on it now
- what reeds does it have now
jetting isn't a standard setup that can be tossed out there, it is a setting that can only be obtained EXACTLY with a dyno. So without a dyno we carb tuners use MAGIC. Help me out on the mods and I'll help you on the jetting.
Old Jul 15, 2004 | 06:59 PM
rdnred's Avatar
Not for sure if it is bored or not the guy i bought it from said as far as he knew it was stock. It has the stock exhaust on it as far as he knew too, but i am upgrading to the ESR TRX5 exhaust. Iwill check on the carb size do u know where it would tell u, or if it does tell u on the carb somewhere. The reeds in it now are stock i am assuming like i said i just bought it and don't know to awfully much about it.
Thanks
Old Jul 16, 2004 | 11:00 AM
Dan250race's Avatar
With new reads and a new reed cage and a new pipe and from the sounds of it, stock carb - I would say: Leave the jetting where it is for now if it runs good with the stock stuff. With a pipe I had to richen and with reeds I had to lean - so that x's them out. Leave the airbox lid off after you get the mods on and do a few plug checks and go from there to set your main jet - the rest of the carb settings are your preference.
Old Jul 16, 2004 | 11:48 AM
trapperb1's Avatar
My standard reply to something like this is, what ever jets you have stock,
and you upgrade exhust/air filter (you are doing this aren't you??), go up 3 main jet sizes to start checking. Adding new reeds will mostly "richen" your motor and you may have to step back down a size.
Start at least 3 jets larger, do some plug chops and determine from there what to do.
I tend to keep mine on the slightly "rich" side, my plug is black but dry, as long as it runs crisply throughout the power band. Running a little rich won't hurt your motor, running to lean will smoke it.
Old Jul 16, 2004 | 12:32 PM
pimp250r's Avatar
If you get the G3 power curve reeds, you will have to bump up your main quite a bit. Probably drop one on your needle and might have to adjust your pilot too. You may want to simply take your airbox lid off or use an outerwears airbox cover
Alex Rodak
Sep 13, 2015 12:30 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
