If you carry duct tape you are guilty
No, I'm serious on court tv with Katherine Crier.
They had him guilty as sin which he may be, because he carried duct tape in his boat.
That would be an item I put on top of my list of supply's. For any outdoor excursion.
What it is, a bunch of city slickers putting guilt on something they have no clue about.
I just hope the guy gets a fair trial.
Originally posted by: AlaskaBayouGuy
My wallet is made out of duct tape - im screwed....
Mr. Minimus,I don't mean to change your topic on duct tape but I have a question about the mods. you have listed. Did you gain any noticable performance with the DG3 snorkle? Did you try running your 700 with just the DG3 snorkle before adding the DG3 module and 4 degree key? The reason I'm asking is I modified my stock snorkle cutting off the restriction part of it and adding on a larger diameter hose. After doing that I lost some top end speed. I was told that the design of the DG3 snorkle( its shape,size,thickness and flanged end) makes it perform better than just putting on a radiator hose of some sort. I'm also using the DG3 module but not the 4 degree key. Where in the power band do you notice an increase in performance using the key? I'm also using a K&N air filter with stock jets. I tried using 142/145 jets but didn't notice any differance in performance. Thanks in advance for your answers. Now back to duct tape. It's the number one tool of use for my car,home and at the nuclear plant I work at.
I think the kicker in Scott's case was all the brown hair stuck to the roll.
As for the snorkle, once my jetting was right I got the same performance out of the dg, the hose, and the factory with the restriction cut off. I'm running rich jets and no lid now, by far the best performance of the bunch. I figure air is air, doesn't matter what shape the tube it comes in is.
I carry duct tape and a rope. Add the fact that I'm married, they might as well put me away now.
