? about oil change
Old Jul 16, 2004 | 01:25 PM
DSengineer's Avatar
Has been here a long time!
Default ? about oil change
I am getting ready to do my first oil change. When I go to pull the hose off that runs from the oil tank to the left side of the motor is it going to immediately start draining oil. In other words do I need to be quick about getting the hose over to the oil pan? Just want to be prepared so I make as little mess as possible.
Any other pointers would be helpful.
Old Jul 16, 2004 | 01:34 PM
shmee's Avatar
yep, you will have a mess. it will come out of the hose but just a little bit maybe 4 oz or so. ps. it probably wouldnt hurt to take that nipple off and look at screen.
Old Jul 16, 2004 | 01:46 PM
DSengineer's Avatar
Thanks. Here are the steps I plan to go through for the oil change
1) Remove hose at motor and let drain.
2) Remove hose and fitting at oil tank and check oil screen
3) Remove oil plug under the motor and let drain
4) Remove oil filter and replace
5) Re-install oil plug and oil hose.
6) Fill with 3 quarts and check level.
Am I missing anthing important?
Old Jul 16, 2004 | 02:41 PM
shmee's Avatar
looks good but pull plug on tank. there is a magnet on it. just something to look at..[img]i/expressions/face-icon-small-smile.gif[/img] it takes about 3.3q
Old Jul 16, 2004 | 02:42 PM
sam's Avatar
sam
sound good, unless the X is differnt I just changed my oil and you will need 3.3 qts. when you pull the plug ( both) from the oil tank you might want to have a rag over the a-arm area to catch the dripping other wise it will go all over the a- arms and stering stem and make a mess. the tank holds most of the oil too.
Sam
Old Jul 16, 2004 | 02:57 PM
shmee's Avatar
if the first thing you do is pull the hose off, there will be 2qts comming out of that hose. plus a good thing is to buy a 1/4 valve from a hardware store and put it on your tank where the plug is. makes things a lot cleaner.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
