400ex Headlight Prob
Old Jul 16, 2004 | 05:46 PM
Yellr400EX's Avatar
Default 400ex Headlight Prob
The other night i pulled up behind my truck in the garage and in the reflection i noticed only one headlight was workin, but that was on high beam, when i put it on low beam both came on. Is the way it supposed to be and ive juss never payed attention or is sumthin wrong because my friends warrior is the same way 1 light on high both on low. If this is not right what do i need to do. Thanks
Old Jul 16, 2004 | 08:22 PM
curlytop's Avatar
that one high beam may be shot, cause there is two filements in those headlights i think.
Old Jul 17, 2004 | 12:15 AM
Jordanw's Avatar
the smae thing happened on my warrior, i took a part the connections and cleaned em and now the highbeams work perfectly [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 17, 2004 | 01:26 PM
IDLE's Avatar
sorry this is kind of off topic but i was wondering how your 400ex does in mud? thanks
Old Jul 17, 2004 | 03:53 PM
Yellr400EX's Avatar
The bulb is not blown and yes it does have have two filaments never thought of that ill try to get someone to look at it...................itll go through pretty much anything as long as you dont bottom out which happens a lot cuz it dosent have very much ground clearance but as long as you stay outta deep ruts your good to go
Old Jul 18, 2004 | 06:51 PM
dynofox's Avatar
My headlights do the same thing. Both bulbs are fine and I've cleaned up the connectors behind the bulb well with no luck. I don't do a lot of night riding but I don't like having the lights not work right.
Old Jul 18, 2004 | 07:59 PM
Yellr400EX's Avatar
is it supposed to be like that then? cuz i never payed that much attention to it but now it bugs me
Old Jul 18, 2004 | 08:50 PM
NotuRaptor2's Avatar
Check your switch too on the handlebar. I also had the positive wire brake loose inside the plastic cover. It was on my 2003 when it was only about a month old. I had to resolder the wire.
Actually, you can forget this advice since one side is working fine.
/Jon
Old Nov 30, 2005 | 11:43 PM
yellow400exrider's Avatar
i have a 2005 400ex and both mine work on high and low
Old Dec 1, 2005 | 01:00 AM
quicksilver's Avatar
dynofox, the bulbs can look "ok" but can still have a problem. Perhaps you have a wiring problem? Check for power on the high-beam wire of the bulb in question, or simply swap bulbs from left to right. If the problem follows the bulb, then you have a bad bulb. It problem stays at the same light, then you have a connection/wiring problem
Whitelx1
Oct 2, 2015 10:55 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
