2004 SCRAMBLER 500 EXHAUST-WHICH GIVES MOST POWER??
Old Jul 18, 2004 | 09:47 PM
badassz24ondubs's Avatar
Default 2004 SCRAMBLER 500 EXHAUST-WHICH GIVES MOST POWER??
MONEY IS NOT MUCH OF AN ISSUE,BUT WANNA KNOW WHICH FULL EXHAUST SYSTEM GIVES THE MOST POWER OVERALL?? ALSO WHICH IS THE LOUDEST??i do want it loud,im favoring the HPD POWERMAXX but still unsure which to go with as there are many companys that make exhaust for this.thanks in advance.
Old Jul 18, 2004 | 10:43 PM
scramblerXrated's Avatar
go buy the newest dirt wheels mag.
there a whole article on pipes. the do dyno comparisons for all of them, even a DB rating.
i personally prefer the white bros Eseries. i just have a stock pipe and header but with the Eseries, there was a huge improvement.
oh yeah,,,,,, it just sounds baddass.
X
Old Jul 19, 2004 | 12:22 AM
DGScrambler400's Avatar
the White Bros. does sound nice, talk to BigBadScrambler, he can help you out.
Old Jul 19, 2004 | 12:47 AM
BigBadScrambler's Avatar
OK, money is no object. So, ask yourself this. Do I need a spark arrestor where I ride? If the answer is Yes, then go for the White Bros. If the answer is No the go for the HPD. Either way, you see an improvment in the bottom end. The HPD kicks in the midrange too. The HPD pipe is a little larger than stock, plus looks a lot better with the nickle plating. The White Bros is your "best bang for the buck" slip-on out there. JMO.
Old Jul 19, 2004 | 10:20 PM
ok thanks to all you guys,i want a full system probably gonna go with hpd. hpd power max has or does not have spark arrestor? thanks again
Old Jul 20, 2004 | 12:40 AM
HPD exhaust DOES NOT have a spark arrestor. However, I would give HPD a call on that. I remember reading somewhere that they were suppose to release a spark arrested version. Don't know if that was true or not
Old Jul 20, 2004 | 10:26 PM
BBS if not, wat is another good full system to buy?? thanks
Old Jul 20, 2004 | 11:54 PM
jmrpage's Avatar
full systems for that bike are a big waste of money . do your self a favor and take your head pipe off , send it out to be jet hot coated ,and buy the white brothers slip on .
Old Jul 21, 2004 | 12:28 AM
If not, then get the White Bros slip-on. Out of the other full systems out their (ProCircuit and Supertrapp), the HPD makes the most power. The other 2 use a pipe that is about the same size as the stock. The HPD pipe is larger than stock which means more air flow. I honestly wouldn't waste my money on the other 2. HPD can back their horsepower claims with dyno runs. The other 2 cant. JMO
Old Jul 21, 2004 | 09:18 PM
ok cool very helpful,BBS,on your signature it says airbox mod,wats that mean?also is a K&N worth the money or should i go with a UNI for my bike? thanks again
