Boring a 250x??
Old Aug 13, 2000 | 02:37 PM
kickAZZ250xer's Avatar
what would u bore a 250x to. It has the same bore as a 250x??
here r the specs of the engine
displacement is 246cc
bore x stroke= 74x57.3 mm(2.91x2.26)
What would i hvae to do to make i around 300cc if that is possible. with out max it out.
what is involed in strokeing a eingine??/
what is the normal size ppl bore thier ex and x'x to??
Old Aug 14, 2000 | 03:24 AM
puddding's Avatar
search the forum chopper
Old Aug 14, 2000 | 09:11 AM
hondatrx300ex's Avatar
330 is what most people bore ther ex to but I dunno about 250x. talk to trick250rx about stroking......
Old Aug 14, 2000 | 01:13 PM
SUP440's Avatar
Stroking involves replacing the crankshaft. This means you will have to split the cases. Replacing the crankshaft will increase the distance your piston will travel, thus improving capacity for air and fuel. It is not for most people, because it is expensive if you can't do it on your own.
Old Aug 15, 2000 | 01:58 AM
how much does a 330 kit typiclaly run??
Old Aug 16, 2000 | 10:08 PM
letitsnow's Avatar
Call Powroll. They will tell you all about it.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Huntingdeer
Aug 23, 2015 12:06 AM
