Major 400ex problem... when will the problems stop??
Old Aug 13, 2000 | 06:24 PM
c400ex1234's Avatar
hi...
My oil resevoir broke when i tried to remove the oil drain bolt... what a poor design by honda... liek someone else said before "i could have done a better job with a soddering gun"
anyways, does anyone know an aftermarket oil rez. that is under 200?? What are some advantages of the DG forward mount oil rez.. is it stronger than stock????
later
Old Aug 14, 2000 | 01:06 AM
Motorhead's Avatar
I haven't had a problem yet, and I've changed my oil twice so far. Maybe I'm one of the lucky ones?
Old Aug 14, 2000 | 12:42 PM
86atc250r's Avatar
I have changed the oil many times in mine, no problems, no evidence of poor design, please elaborate.
Did someone apply a little more torque than they should have?
c400ex1234's Avatar
I went to the dealer and they told me that a stock oil tank cost 175!!! WHAT A RIP OFF!! does anyone else have a different number?
Old Aug 14, 2000 | 12:51 PM
SUP440's Avatar
You should be able to get another Honda oil cooler for about $145. DG no longer makes theirs????????? I don't know why. I would spend the extra money for the pingry.
Gabe, I know it sounds like people are applying too much torque, but until you see the inside of the tank an the small weld bead holding it on, you couldn't possibly understand. I have never seen Honda build such.
If anyones happens to break try to find a local welding shop. I believe that they can be welded back better than before. The only problem being they are so thin.
Old Aug 14, 2000 | 02:04 PM
c400ex1234's Avatar
one question.. and this is very important... IS it ok to use a 3 quart oil tank if i still have a stock engine???
Old Aug 14, 2000 | 04:17 PM
HILLSVILLE69's Avatar
i dont know? but i have seen this happend to two 400exs
Old Aug 14, 2000 | 04:36 PM
86atc250r's Avatar
Of course it is OK to use the 3 Qt tank on a stock engine, heck the engine wouldn't care if you hooked up a 55 Gallon drum to the system. It's just a holding tank....
Old Aug 14, 2000 | 05:00 PM
TheGerk's Avatar
they will stop when you guys stop fooling with them and beating them into the ground.
Old Aug 14, 2000 | 05:16 PM
supertraprecon's Avatar
BAH!
