Do any sport quads come with 11" front rims?
Old Jul 20, 2004 | 11:11 AM
MikeyBoyesq's Avatar
Default Do any sport quads come with 11" front rims?
DOES ANYONE KNOW IF OTHER SPORT QUADS COME WITH 11" FRONT RIMS??? I put a 10" rim up to my P650's front hub last night to see how much room I would have if I mounted them and it appears that I will need a 10" custom rim with only a 1" offset on the inside so that the inside of the rim won't rub against the brake caliper. Ideally, it would appear that I might be able to use an 11" rim with a deeper offset (so that my brake rotor is inside the "bell" of the rim and thus protected from rocks, etc. I have heard of 11" rear rims on other quads, but don't know if such a size exists on front rims. Anyone know?
Happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 20, 2004 | 11:53 AM
newbeatle's Avatar
got ya on the other forums, but posted here, for the benifit of others...
MIKEY... a quick & dirty check of my references, shows...
2 X 4 Honda Recon TRX 250 - '97 - '01, with a front 11" X 7" wheel, 4 on 110 mm
2 X 4 Honda Four Trax TRX 300 - '88 - '92, with a front 11" X 7" wheel, 4 on 110 mm
4 X 4 Honda Four Trax TRX 300 - '88 - '92, with a front 11" X 7" wheel, 4 on 110 mm
4 X 4 Honda Four Trax TRX 350 - '86 - '89, with a front 11" X 7" wheel, 4 on 110 mm
4 X 4 Honda Foreman TRX 400 - '95 - '03, with a front 11" X 7" wheel, 4 on 110 mm
_____________
OK... jack pot...
_____________
4 X 4 Kawi KLF300 Bayou - '89 - '04, with a front 11" X 6" wheel, 4 on 137 mm
4 X 4 Kawi KLF400 Bayou - '93 - '00, with a front 11" X 6" wheel, 4 on 137 mm
4 X 4 Suzi King Quad LT300F - '91 - '98, with a front 11" X 6" wheel, 4 on 140 mm
thats it for my references... I still have never been able to get a 10" in the 4 on 137mm pattern, but admit, that I haven't looked for an aluminum 11" in 4 on 137 mm the original Bayou wheels are going to be steel... good luck on your search, & let me know how it goes...
I always thought that the Bayous had a 12" front tire... I suppose either I or the reference material are wrong though...LOL...
Old Jul 20, 2004 | 01:05 PM
Thanx for the quick feedback Mike. I was actually hoping that someone could tell me about a sport quad that comes stock with 11" front rims and 22" tires.
The above info is good to know...especially about the KLF300 and 400 with same bolt patterns as my Prairie...however, I have to ask if anyone makes a 22" front wheel that fits on those 11" rims you mentioned above. My guess is NO b/c those quads above are utility quads and usually have at least 24" or 25" tires mounted on them. Any thoughts?
Old Jul 20, 2004 | 01:25 PM
newbeatle's Avatar
MIKEY... most of the Hondas are sport quads... there are a slug of tires available in 23" O.D. for the 11" front rim...
the only tire I could easily find in 22" X 7" X 11", is for the Suzi Ozark, & that was a Dunlop KT 151... but since the Ozark is relitively new, perhaps there are others ???
DTroyer01
Jul 3, 2015 07:34 AM
VascoConroy
Jun 12, 2015 10:30 AM
four50four
Jan 15, 2000 03:39 AM
ZJnut
Dec 30, 1999 08:33 PM
rodman1
Aug 21, 1999 03:05 PM
