Thinner head gasket for more compression?
Old Jul 20, 2004 | 11:37 PM
KISSSOFDEATH's Avatar
Default Thinner head gasket for more compression?
Has anyone ran a thinner copper head gasket on a P650 to raise the compression with a stock piston to 11:1?
Yes or no. If yes please give the website or email where the gasket came from.
Thanks
Tim
Old Jul 21, 2004 | 12:10 AM
cueball89's Avatar
Head gasket post
I think they are about $70 from comet, wiseco 11:1 i think are only $120.
Old Jul 21, 2004 | 12:27 AM
Yellow650Rincon's Avatar
Just a word of caution, incase you didn't already know. You run a higher risk of blowing the head gasket when using a thinner one. Just to let you know! [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 21, 2004 | 12:30 AM
Thanks cueball, Im getting ready to port and polish the intake and heads on my P650. Also going to go with a new 11:1 stock size piston or hopefully just change the head gasket to get the 11:1 out of my stock one. Im also going to go with Mickey D cams but havent talked with him about those yet.
Im wanting to make my P650 run with the new BF750 for as little money as possible.
Old Jul 21, 2004 | 02:01 AM
Even if its copper?
Old Jul 21, 2004 | 02:06 AM
I'm not sure. All I know is that the thinner the gasket, the higher the risk of blowing it. Rasing your compression ratio one full point sounds like a big jump in gasket sizes. I really can't say too much, I'm not that educated on a Prairie. lol
Old Jul 21, 2004 | 09:00 AM
SHOTGUN's Avatar
KOD;
I think the Cometic gaskets are made to go with the high comp pistons. If your getting new pistons, just buy the 11:1 ones, the price will be the same, they'll have the valve pockets made in them.
be careful of how much squish you have with thinner gaskets,
Old Jul 21, 2004 | 09:04 AM
newbeatle's Avatar
I agree with the "squish" thing, there is very little ( in reality ), difference in compression ratio, between a good quality ( thicker ) head gasket, when properly torqued, & a thinner, harder head gasket, when properly torqued...
Old Jul 21, 2004 | 09:44 AM
Thanks guys, I seen the comet gasket last night on their site for $70. I havent called or emailed them but I wonder if that is for 1 or 2 gaskets. Thats a high price it should be for two. The reason for trying to find thinner head gaskets is to save money over buying new pistons. I will be doing this work myself with the help of my brother in law and I want as little money invested in this job as possible.
However I will do what it takes to run with a stock BF750.
Old Jul 21, 2004 | 10:08 AM
SHOTGUN's Avatar
I would think with your modds, just a degree key and cam timeing advance would put the BF in your rear view mirror.
