Raptor idles good, give it gas and it spits n chokes
Old Jul 21, 2004 | 01:58 AM
hellrider2001's Avatar
Default Raptor idles good, give it gas and it spits n chokes
Starts good idles fine chokes out when I get on the throttle chugs n backfires. I have good spark and its not fouled out or wet??? HELP ME
Old Jul 21, 2004 | 01:59 AM
warrior68man's Avatar
I would believe your parking brake is on.
Old Jul 21, 2004 | 02:00 AM
How do I get it off?
Old Jul 21, 2004 | 02:03 AM
How do I turn my parking brake off???
Old Jul 21, 2004 | 02:05 AM
bvwarrior's Avatar
just gigle the parking brake on the handle bars, or it might need to be adjusted, but it also sounds like you might be running lean, also my warrior was doing that and it was the boot connecting the carb and motor, hope you fix it !!
Old Jul 21, 2004 | 02:08 AM
Just before this happend my friend was messing with the parking brake, But I dont know how to disengauge it or just disconnect it period I never use it anyway do you know how I could do either
Old Jul 21, 2004 | 02:17 AM
bvwarrior's Avatar
to turn it off, i had to disconnect the sensor that was plugged in to the parking brake,'' but not the 1 in the clutch handle, the one on top of it for the parking brake'', i pulled it out of it's hole and found away to keep the pin pushed in, so it would run normal, but only try that if there is nothing else you can do !!, try adjusting it first, then the sensor but don't brake it, then try removing it completly.
Old Jul 21, 2004 | 02:19 AM
What do I do to adjust it?? And is it possible to just disconnect it to prevent this from happining in the future??
Old Jul 21, 2004 | 02:20 AM
BURKEDADDY's Avatar
you can take off the ebrake for under 30 bucks you need a block off plate and a new clutch lever and perch about 30 shipped on ebay you dont have to put a new clutch lever on but it just looks better with out all that ebrake stuff all over it and come to think about you dont need a block off plate it just looks better.
welcome to the forums i think youll find that this is hands down the most helpful forum on atvs out there
Old Jul 21, 2004 | 02:34 AM
How do I adjust it so I can ride and it will run like it should, or can I just disconnect it completely somehow????
