Yamaha moto 4 350 not sure of the year.
The serial number on the Moto4 350 is located on the lower left frame rail. The easiest way to describe here the exact loaction would be to look at the lower left frame rail between the front fender and the toe rubber on your gear shifter. It will be 17 characters long. The stamping isn't deep, so even minor crud will hide it from you unless you clean the rail first.
Another trick to reading the slight depression numbers is to throw a bit of cooking flour on there after you wipe the area clean. Those numbers and letters will stand out then.
Good luck
Good luck
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
