mixture screws
Old Jul 23, 2004 | 12:35 AM
shortyno11's Avatar
Default mixture screws
does anybody know where the mixture screws are on the kfx 700?
Old Jul 23, 2004 | 01:01 AM
trailride's Avatar
On the bottom of the carbs.
Try this site www.700v.com
Kevin has alot of info you will like
Old Jul 23, 2004 | 01:06 AM
Russ700KFX's Avatar
Right side of carbs. On the bottom edge of the float bowls. Brass screw....
Old Jul 23, 2004 | 01:47 AM
shortyno11's Avatar
are they sticking out or are they screwed in? i just bought a fmf jet kit, and i got the needles in there but i dont know what the mixture screws look like.
Old Jul 23, 2004 | 01:52 AM
Heathen's Avatar
They are recessed in the bottom center of the carbs. They are slotted for a regular screw driver.
shortyno11's Avatar
the screws i need to change are pretty small. and do i have to take the carb off like they show on the 700v.com site
Old Jul 23, 2004 | 01:53 AM
shortyno11's Avatar
o. ok. thanks a lot u guys.
Old Jul 23, 2004 | 02:05 AM
shortyno11's Avatar
what do people mean by re-jetting to 120f, and 124r and stuff like that. what does that mean, and will i have to do it since i have a jet kit on it?
Old Jul 23, 2004 | 03:17 AM
Russ700KFX's Avatar
The 120f 124r designates which size jet goes in which carb. f = front. r = rear. The larger the # of jet, the more fuel it can flow at wide open throttle. Which is typically what you need when you do an exhaust or intake mods. The jets - usually along with different needles... and sometimes small shims... is what makes up a jet kit.
Old Jul 23, 2004 | 09:50 PM
shortyno11's Avatar
so am i going to have to re-jet? the only mod i have is the fmf jet kit.
